i am going to be really nice people =D
really and quick way of installing a flip flop boot if you dont know what this is pic below:
Materials:
2 - 2" Slide Bolts (Latches)
2 - 3” Strap Hinges
Flip-Flop Trunk Lid Instructions
Drill with small bit (1/16” to 1/8” depending on the size of the screws) to predrill
screw holes and a large bit (5/16” or 3/8”) to drill for the latches in Step
#6
Phillips screwdriver (the screws should come with the hardware)
Instructions:
1. Remove your trunk lid by unbolting 4 bolts. Do not remove the stock
brackets, only the trunk lid. You may have to remove some wiring also.
Just remember where everything plugs back in. This part will take 2
people.
2. Attach one side of the hinge to the side of the bracket that was
connected to the trunk with the hinge facing away from the trunk.
Repeat on the other side. Make sure to pre-drill your holes.
3. With help reconnect the trunk to the brackets using only the bottom
bolts (the top ones won’t go in because the hinge is covering the hole for
them).
4. With the trunk in place, pre-drill and screw in the screws for the
other side of the hinges. You may have to bend the hinges slightly to
get them to fit right. A little pressure or a small hammer will do the
trick.
5. Connect the latches about 2 inches from the bottom of where the
brackets touch the trunk lid. Be sure they are mounted on the inside of
the brackets.
6. Mark a spot on the stock bracket to drill a hole to allow the latches
to latch (this is where the big drill bit comes in). You may have to
remove the bottom bolts to drill so you don’t damage them if you ever
want to put it back to stock. Be sure the latches will close tightly. If they
don't you may have to replace the bottom bolts each time you want to
fold down your trunk lid. (If you don’t plan on using this trick too often,
you can skip the latches and just replace the bottom bolt anyway. This
will keep it very secure but still let you use it when you really want to.)
7. Once you have the latches on, you can remove the bottom bolts if
you haven’t already and flip the trunk down. The hinges will let the
trunk fold down to level, but not any farther. To close the trunk flip it
up, slide the latches into the holes you drilled in step #6, and close the
trunk normally.
8. If you have some subwoofers in the trunk, you might want to put
some foam tape along the stock brackets to keep the trunk from rattling
against them.
i have attached a PDF version of this tut, it includes pictures please let us know what you guys think =]
Flip_Trunk_Method.pdf
You Ordered a flip flop boot? lol are u serious hahah how much did it cost u???
cause this tut if you do it right will cost you around 15 dollars for the mod =D hehehehe :D well good luck heheh
HOLY S**T :o Well they suckered you in, that is way overpriced
Unless it's one of those really good ones. I can't find a link to it, but from memory, it used those gas struts and the boot opened completely flat and really smooth.
you are correct djkor i have bought a good brand flip flop trunk not the cheap one where you pull a pin out and it folds down here is a video of how it works
Please wait a few seconds for Video to Load!
sean
p.s im not that dumb trent lol
^ Yeah Sean... that's the type of one I was thinking of.
yeah i dont like the one one where u have to pull out the pins to make it flop and i wouldnt pay that much for that kit im happy to pay 150 aus for this kit the only thing i dont like is that it wont be here till end of the month due to stock
sean
yer tru tru but at least u save like alot of money doing it this method but then again its up2 you and its your money :)
      2006 Aurion 222000kms
      Tyre Sale Specials
      overheated engine
    6. 62
    9. 1
      Tyre Sale Specials
    10. 10
