TRD Suspension Kit
I have a 2010 Corolla, The original suspension is too high.
I am considering changing to the TRD ones. They have a suspension kit for corolla.
How much does it cost and are they good?
Any alternatives to those things?
TRD Suspension kits are good but very expensive (They're TRD after all) if possible, look for alternatives cause TRD Suspension are made I think by KYB... ;)
TRD are great equiptment no question there but there are many suspension makers out there the likes of KONI and BILSTEIN would be more then what you would require matched with KING springs a very good quility spring you would be in business plus if you want height ajustable you can do it with both makers and some come with a sport mode .
http://www.bilstein.com.au/
http://www.proven.com.au/content/koni-proven-products-shock-absorbers.html
hope this helps .
For the TRD suspension set, you'll be looking over $3000 from the dealers.
Here you go! http://trdparts.jp/english/list_auris.html :)
I have tried the TRD Setup (le.vinh), it is pretty good but then again, it depends on what you're after.
Some people like oem or something that will fit 100% guarantee (TRD), some like to change just the springs/coilovers (for looks and/or harder spring rate)..
It is possible to go a good suspension setup without going the TRD route. Good set of springs & shocks, plus maybe a sway bar. Might be slightly cheaper but once again, it's up to the user's needs. :)
Peter.
