[WA] 2ZZ-GE Ported Head
So I don't have many bits left. The thing I really want to get rid of is the 2ZZ-GE ported head. As I have explained before it is ported on both intake and exhaust sides. Valves and springs still intact. No cams, no valve cover, no manifolds.
$300
Also still have some genuine facelift headlight protectors for a ZZE12#
$50
Edited by and1
  • Replies 101
  • Created
  • Last Reply
Top Posters In This Topic
as you can see in the pics he has two sets i guess
Yep. I found my old pair.
Andy you want? Let me know..
hrmm not sure how it wld look on my car ...
Would look like how it is on my car LOL
Is it possible to change out the stock wheel nuts to aftermarket ones? (Think you can't)
But if you can, what size are they?
No won't fit the stock wheels. Stock wheels use a shank type nut whereas these are conical tapered nuts.
I have listed the sizes of the thread in the first post.
Wheel nuts are for aftermarket wheels.
Pretty much only the stock nuts can go with stock wheels?
What's the difference between the close and open ended nuts ?
Well one is closed and one is open :P
The closed is steel and the open ones are aluminium.
hey dude can i check out ur eyelids next time i see ya ? so i can have an idea how it will look on my car =]
Sure no worries.
Bump!
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
