Which pad should I get?
W58
Does anyone have a W58 Supra Gearbox for sale please? Or any realistic suggestions as to where I can source one? -
help
got a 2010 kluger got a thump or a knock coming from the front end to the steering wheel turning right and left any ideas would be helpful thanks -
Aurion dead steering feel any way of fixing it?
Yeah they feel like a boat. Even with Pedders sports springs. I did have success running 2 deg negative camber on the front using adjustable camber bolts, along with 235/45/18 kumho's. Was alot of fun around corners, but it came at the expense of loss of grip in a straight line and ruined the tyres with camber wear fairly quickly. -
I am looking at a 2012 Aurion sx6 Sportivo. Lovely car but the steering lacks feedback and feel to me. I really want to buy it but don't like the steering. Is there any way of improving the feel? Different tyres or different power steering fluid etc? -
New member - RAV4 owner
Welcome to the forum and Congrat's on the new baby, I am sure anyone who can help with any questions will reply KAA -
sahara
I would like to know if my 2005 Sahara 100 has a separate fuel pump? or uses same as main?. And where is the drain plug for the sub tank ? i see one at the bottom of the tank bat not sure if its only for the main tank ? could anyone has any info on the above please? thanks. Nat -
Touchscreen unit for 2012 Aurion Sportivo zr6 cost
Actually I made a mistake. It's an SX6 not ZR6 so yes it has the correct touchscreen in the boot but I still have to get it installed and the aftermarket one removed. -
I have found an Aurion 2012 sportivo zr6 model which will make a nice daily driver. Problem is the original touch screen centre unit is missing and has been replaced with some large aftermarket touchscreen that pairs with your phone. The seller showed me the original touchscreen in the boot which he says can be re-installed quite easily. Problem is the "original" touchscreen in the boot is a basic one from an ATX base 2012 model rather than the sportivo model which is far more comprehensive and includes GPS etc. The car is priced quite cheaply in accordance with it's condition. Does anyone know approx how much I will be up for the purchase of the proper replacement touchscreen unit including installation? Thanks in advance 🙂 I'm a Ford/Holden diehard who happens to love Aurions. My other car is a VF SSV and my previous car was an XR6 Turbo but I still love these Aurions...very underrated car indeed. -
7
I have a 2022 Kluger that started with a higher consumption but after about 1000+ km, has settled in to around 6.6-6.7 l/100km on journeys, covering up and down steep passes, and a range of conditions. I occasionally use E10 but use 95 when I can find it, along with 98. I drive to enjoy it (within the law!), so I'm not always feathering the throttle. With nudge bar, lights and roof racks, I haven't noticed an appreciable difference, the only situation that really knocked the consumption around was towing a dual axle trailer from Wollongong to SW Sydney which sent the consumption sky-rocketing due to the wind resistance of the load. -
