Hey All
Just upgraded the clutch and flywheel hopping it would fix the problem with 3rd gear ( crunches all the time even just sitting there ) but no such luck. The guys at the shop told me it would be the syncro. to replace just 1 syncro would cost $600 or the rebuild the whole box with new beaings and syncros $1200.
Do these prices sound right? they seam fair to me.
If i go ahead and do the whole box is there anything elese i can do to streghten it while there there?
Any sugestions as i only want to do this once.
those prices seem to be alright... but if ur rebuilding the box, might as well chuck a lsd in it too :P
Those prices are cheap, I take it the box is already out then?
3rd gear synchro is a pretty common problem with the 6 speed box. Luckily the parts are cheap for the box since it's been around for 20 years or so in one form or another.
thats what i was thinking but a little out my price range right now...
nah the whole car is back together
20 years really?
if u can spare the cash i would recommend getting a celica 6th gear since chances are the shop will break ur 6th pulling it all apart .... hey they might not but if they do putting the celica 6th in will get u those extra revs for smoother highway cruising.
also i would highly recommend the extended push rod
http://www.monkeywrenchracing.com/product_info.php?cPath=25_111&products_id=717
also the shifter cable bushings set
http://www.monkeywrenchracing.com/product_info.php?cPath=25_136&products_id=720
also if u dont have a TRD shifter kit then would also recommend the shifter base bushes being done also
http://www.monkeywrenchracing.com/product_info.php?cPath=25_136&products_id=721
all thse together provide a nice end to end solution for ensuring smooth shifting operation
I didn't break the 6th gear, but still put the celica 6th gear in, 4k rpm gets me 139km/h, before used to get me 120km/h
Sounds like a plan. Where can I pick one up from? And what should I expect to pay? Cheers
From that monkeywrenchracing website
u get both driven and driving gear. Look it up
0.75:1 ratio
http://www.monkeywrenchracing.com/product_info.php?products_id=1156
is this what you were reffering to? its all i could find on monkey wrench under 6th gear pairs
Yeh thats what i found. If that it im getting one. might say for a lsd and do it all together....
Would it be ok to dyno it with a syncro out? all they do is leave it in 3rd right so shouldnt be to bad???
yep def get the LSD in their if its an option for u ...... im running the quaife lsd and man what a difference it makes.
regarding the dyno if its only the synro if shouldnt cause any more damage than ur usual driving ..... however if u actually have gear damage then ur simply putting more load on an already damaged gear
whats the difference between
Toyota OEM 6th Gear Set - C6X - 0.715:1
and
Toyota OEM Final Drive Gears - C6X - 4.3:1
What is final drive gears???????????
Final drive is your diff mate.
Arhhhh now it all makes sense. Nobody laugh
are there a few people keem on a 6th gear pair i wonder? i can probably get a slightly better price off monkeywrench for multiple sets as im getting a set soon, also they just price dropped yesterday too haha.
I'm keen
where is the cheapest place to get the quaife lsd dont want to pay the tax and import charge
Posted (edited)
no go with the multiple sets of 6th gears from mwr as they want me to spend 2500 minimum and become a dealer haha o well they are cheap as at the current price anyway
Edited by daniboy
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
