WTB FRONT SWAY BAR + P1 BUDDY CLUB RACIG RIMS
Long time no update. In all honesty, not an awful lot to update on. Life has been super busy and inbetween life, I get a chance here and there to clean the beast and also arrange for the usual 5000 km oil change. The car is showing it's age with more noticeable paint fade on the roof. After some time I've decided to order the parts to fix my slow power steering leak. After receiving the quote from Toyota, I was able to get the parts from overseas for not even a 1/3 of the cost it would've cost me to order here. The parts are due here in 2-3 weeks and I'm thinking of getting this done with the major service which will be due later this year at some point seenig as the car is quickly approaching 293000 kms this month. Other than that, I'm still enjoying driving the car and the money spent late last year was well worth it. -
9
Vibration through body (not steering wheel) under acceleration
I've noticed the same issue after changing the front shocks from OEM to KYB - and while I don't think the shocks are to blame, it could be that there's been an issue which the old shocks covered up by not working at all after 230,000kms. I've also changed the CV joints in mine, replaced the front suspension bushings; hoping that a wheel alignment and new tyres helps this - will post back in the morning the result. Adam, -
P0420 Catalystic converter below Thrushold
My kluger gives p0420 code even after changing the catalytic converter I’m help less now I so much money but no mechanic is telling the truth. Please help solving this issue thanks in advance -
Dashlight dimmer
I scored a nice fairly low kms 1992 toyota starlet as a run about for work,my problem is at nighttime the dashlights are very dim and the clock is almost non existant,ive searched the dash from top to bottom and cant find a knob,switch or anything else to do with adjusting the dashlights...can anyone help me with this problem? -
Electrical issues
Hi all him having some issues with my 2018 prado. Head lights keep flickering when I put high beams on now head lights won't self turn off also reverse camera takes ages to work and Stereo randomly turns of and back on when I'm driving just wondering what it could be -
New member
hi all, im Neil,i live in new zealand & ive just scored a 1992 toyota starlet soliol -
Rav4 2016 ZSA42R 2WD CVT failure
Hi Andrew, just wanted to see if you were able to get this fixed? What was the issue in the end? My car has just started making this same noise (2016 Rav4 - 97000km) and I'm worried. I've had the transmission fluid checked and replaced but the noise is still there. -
buying landcruiser 80 auto vs landcruiser 100 manual
Hello, just need advise which one to buy $6000 landcruiser 80 automatic or $8000 landcruiser 100 manual both 350k odometer -
Gen 6 Cluster Backlighting Issues
When the fuse blows do your f & R parking lights still light up -
Hilux surf
Hi guys I have a 1994 hilux surf and the engine light comes on sometimes I've had it looked at and it has a code g26 the mechanic is not sure what it is dose anyone know what it could be also it won't rev past 3k
