Corolla Sedan Owners
you might be able to get custom shims put in to make camber in the rear but not sure and it probably not much camber unlike other cars when you slam them the suspension in the rear gets tucked in
  • 6 months later...
Sorry for bumping an old topic but I found it while searching a couple of days ago.
Anyway after spending a couple of minutes under my car today I can say there is definately visible camber in the rear of the sedan & my car is absolutely stock apart from from the rims, but given Screaminrollas reply I guess this is normal eh ;)
Unless my eyes can pick up >1 deg...
Edited by Conquest
Get an alignment and it'll tell you that your running about 1 deg neg camber. mine has 1 deg neg on the RHS and 1.2 on the LHS according to my last W/A.
What do you mean by LHS & RHS i.e. are you looking from the front or rear?
I'm used to NSR & OSR, been looking at too many quotes in the past :P On mine the passenger side is a little less than the drivers side so that sounds about right I suppose, but i'm surprised that such a small difference would be visible to the naked eye.
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
      ASV50 Camry Head Unit Options
    8. 2
