ZRE152R TRD Rear Sway + ?
qf380
cusco front strut 942 540 A
Cusco rear sway 942 344 B16
just wondering if these will go with the zre152 sedan as well? i've read they have the same chassis but i just want to be really sure.. :ph34r:
Yep, sedan and hatch have the same chassis! If you can't get both at the same time and don't know what to get first, I would say get rear sway first. :)
Thanks! :D just wanted to be sure! :D
I'd have to say get the Front strut first. The difference compared to stock is quite dramatic, stops a lot of the bodyroll and makes your handling so much more controllable.
True John. I guess it depends on your driving style; I've always like my rear to be more sharp and flat around corners.
  • 1 year later...
That's the reason I google and found this forum, too much roll and under, even at low speed on a round about.
Sorry have been out of the car scene for a while, other than RMS as mentioned above, where else can I get struct bar from in melbourne? Just trying to see what options I have.
Cheers,
Gary
Cheers,
Gary
Gotta order em overseas and get it shipped i think,
Check out the different bars in the 'Suspension' section of the ZRE FAQ
As from places to get, locally there is only from members selling and from K-Mac (John/juvenille Sydney area)
Overseas is where we get most of our stuff unfortunately. You can get them from greenline, rhdjapan, RMS, TRD
      Central locking
    2. 1
      El44 Paseo distributor
    3. 0
      Brake Rotors 2013 Toyota LC200
    4. 1
      2019 camry ascent sports does not have android auto
    5. 1
      Toyota Allex/ Run X headlight retainer clip
    6. 1
      Engine Cost for Sportvito SX6 2007
    7. 1
      1990 Seca Backfiring - Carby and Fuel Pump Overhaul Required
