Widest Wheels on Aurion
BNO
Evening!
Im about to get a set of wheels for my Aurion, however Im unsure if 9.5" width will fit? If not whats the widest I am able to fit.
I have spoken to a few people but I get mixed answers so :S
Dan :)
Dpends on what size u want to get and the offset, and as long as you can stretch your wallet for additional work to fit, evrything's possible.
1 member here that went to the most extreme, is INDOMI, a camry user. Since camry has a similar set up with an Aurion, I figured it's theoretically also possible for Aurion.
20x10 +10 and 9.5+16. Don't even start asking about how and the scrubbings, other issues..
for a daily driver i would go 19"x9" all round with a 245mm tyre and you will have no scrubbing issues,but as said above 9.5" or even 10" will fit on the rears...just :blink:
offset and how low you roll will also come into play
      Fuel filter change - start stops running
    2. 17
      Wobble at the front
    3. 7
      Brake issues
    4. 10
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    5. 25
      RADIO CODES "HELP"
    6. 17
      Wobble at the front
    7. 11
      rear wheel arch hole covers (3rd row seats removed)
      2013 Kluger grande Bluetooth music issues
      2010 MANUAL Prado with high speed acceleration hickup
    10. 1
