Ae92r, front wheel bearing, q. Pressed into the hub or bolt on.. ?
Got a big list
Drive shaft boot
Rocker cover gasket
Distributor seal
Crank seal
Cam seal
Timing belt kit
Wheel bearing
Fix rust
Wipers
Service
Indicator lense..
pressed in. You press the hub out of the bearing, then press the bearing race out of the carrier after removing the circlip. Clean up the carrier, press in the new race, install the bearings to the race and then press the assembly onto the original hub if it's in decent condition.
Wreckers it is lol
Sorry weekend job not a job at work do I don't have a press in the boot.
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
