Posted (edited)
It's a camry with an aurion front 100%. I almost bought that car but got sold before I could go see it!
You'd be crazy enough to convert your car to a single exhaust ;)
Edited by fivese7en
i know this is off topic but is the american camry the same body as the aurion?
just like the camry is the same as a aurion over here
the american camry has the same shape as the gen6 camry , with a v6 under the hood.
the aurion is the australiasian camry v6 equivalent
as in the suspension setup?
i would say the US v6 camry and Aurions have the same susspension setup.
I know the camry sportivo here and in the US have different suspensions. Not sure about the stock models though - might be different or the same as BigVan said.
keep in mind the v6 gen6 camry is heavier than the 4cylinder we have here.
that is why i said the aurions "should" have the same suspension as the US v6 camrys,
because the aurion is technically the same as the gen6 v6 US camry , only difference is shape/design/concept and driver side.
That being said the components should all be interchangeable due to the same/similar chassis being used.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
