6x9" or 6.5" speakers ? which ones have people used ?
Help - Blowing white smoke
So I replaced the PCV Valve and for a couple of days, it was great no smoke. Then yesterday the white smoke was back when I started the car only. It seems to be only when I start the car now, which I suppose is bonus. Any other suggestions? Your help is greatly appreciated. -
With Toyota entering Aus Super Car racing
With Toyota entering a V8 Supra into Australian Super Car racing will Toyota have to keep building the Supra past 2025 ? Also, will Toyota have to build a V8 road going version of the Supra to comply with Super Cars construction rules ? -
Passenger footwell wet ? roofracks?
More than likely cabin filter not fitted and blocked AC evaporator drain blocked -
26
Head unit sd card issue
Hi good day I downloaded the 4 files on to a sd card that I formated in fat32 when placing it in the deck the screen would blink 😅 and thaz about it .. Has me wondering 🤔 if it's files or flash issue -
Toyota Prius 2012 code
Hi Joe I am guessing but I would google and ask how to change the language to English.. then should be easier .. Cheers -
Engine and radiator leakages
Hi Ind, Thanks for your suggestion. Do you know of any mechanic who does change the entire engine assembly and the radiator? Cheers, Lou -
4
2018 SL. Reversing camera display stopped being animated.
Apart from trying the same thing in a different gear and/or moving slowly as you turn the steering wheel each way I don't know what else to suggest. The battery being disconnected was what caused my issue. -
2019 Landcruiser 200 Map update Bricked System
Adam, reality is whilst it is handy to have an onboard GPS unit working, we have resorted to using Google Maps on the phone. It is accurate and always up to date. WAZE is also another App if you're into that. -
When the car runs/idles does it have a ticking noise coming from inside the engine? And also are you loosing coolant from the radiator? After you run it for a while does the temperature gauge in your dash go beyond the safe level? If you need to replace it the costs of the engine and radiator won't be much if you could get it out of a wrecking yard but the garage labor is gonna be costly. -
G'day, My Toyota Camry 2004 Altise has Engine and Radiator leakages as informed by my mechanic. When I start the car, it runs smoothly for about 10 minutes but then has to be stopped as I notice the yellow engine icon lit on the dash board. The car starts to shake a bit, at which point I stop it and let it cool down for about 10 minutes. Sometimes, it starts and runs for another 20 minutes before coming to a halt again. My mechanic suggests complete change of engine and the radiator. Any suggestions if replacing the old engine and the radiator would help me to keep the car? Any ideas of how much will all this cost? Any info on car mechanics that replace engine and radiators would be of great help. Cheers
