Sportivo wheel alignment specs
Mellow
Right, so I'm putting some new shoes (Bridgestone RE002's) on my Sportivo today and getting a full wheel alignment done. It comes with a full digital print out but so I can compare, do any of you guys have the factory wheel alignment specs?
^ Toe can be measure in mm or degrees, pretty sure manual gives the measurement in degrees
Im fairly sure factory specs for a standard corolla are +0.7 or +0.5 mm on each side, so sportivo will probably be the same
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    6. 4
      2013 camry for sale
      Rav4 smart key keyless entry
