2002 Camry Sportivo Cruise Control not working
queequeg
Have a minor issue and I'm not sure how to fix it, I think it was my fault as I had to remove the panel where the air-conditioning and fan controls are as they stopped illuminating when you turn the lights on (had to disconnect everything to remove the panel), and replaced it so now it lights up, however since doing this, the speed alert, cruise control have stopped working and the engine light is on.
Wondered if anyone out there has any ideas, i tried disconnecting the battery hoping that a reset might help but hadn't.
  • 4 weeks later...
  • 4 weeks later...
well, we think we solved one issue - the engine light is the result of a fuel line sensor, just waiting for the part to arrive to check that solves one problem. So isn't solving the speed alert and cruise control.
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
