Wiring help needed
Peter Davidson
I've brought my daughter a 1995 pickup with the 22r engine (petrol) it has just stopped dead fuel ok but no spark almost like it has a hidden kill switch. power everywhere except to the coil. Wondering if anyone has a wiring diagram.m so I can chase the wires out and find the fault thanks in advance.
Make sure the wire from the negative side of the coil is not grounding anywhere,also check to make sure the points are not pitted/burnt or if they are actually opening.
      Fuel gauge wander
    2. 41
      gas smell when driving hard/takes long to start
    3. 0
      O2 sensor issues
    4. 0
      2012 Hilux with snorkel stopped after getting stuck in water
    5. 21
      FUEL WARNING MESSAGE
    6. 21
    7. 2
      MWR Oil Pump
      1993 Celica 2.2
    9. 2
      MWR Oil Pump
    10. 0
