Hi Guys,
Can anyone recommend any particular method or product to help remove stubborn dirt and staines from your factory Sportivo rims?
Ive tried a soft toothbrush and mild soap/detergent yet no decent results :angry:
Any suggestions would be great!
Cheers
Get the wheel cleaner by Meguiars for clear coated/painted wheels. Spray on then give a bit of a scrub with a soft brush/sponge. Should do the job.
Small hint to make them easier to clean.... Polish your wheels with the same polish you do your car as the stock wheels are painted with a clear coat and putting a good polish on them creates a protective barrier against grime and makes them heaps easier to wash. :D
Thanks for your advice Silverbullit. :)
I will be going to buy some of the Meguiars wheel cleaner today.
i use the Acid wheel cleaner everytime, and ive got the Toyota Factory Alloys. they dont harm the paint. just read the instructions. it will get rid of everything! its superstrong.
I know that Brennden will hate hearing this, but I use my high powered pressure cleaner. Granted it is only the $60.00 cheapy GMC one from Bunnings, but hey - it works....
try alittle laquer thinners on a cloth then rinse with warm water.
The best way to get rid of stubborn stians from tyre black, grease, road grime, tar and other wierd crap that u dun even know wat it is or came from is.........After u have washed ur car and u still have those stains use "Poly-Glaze" "BUG & TAR" remover!!!!!! It is awsome stuff its mainly used for the car body but is aslo great for removing noticable fine scratches too!!!!!!!!!!! :D :D :D
will definatly add that to my list of car care items!
you can get it from autobarn and other auto product shops even kmart i think???
It is in a black bottle and has a angry looking bug wearing a racing helmet on the label!!!!LOL
lol! so all i need to do is look for a black bottle with the crazy bull frog on it! :D
Not at all my friend, good to see you are using some of my advice lol. High pressure will remove the majority of the grime off your wheels then it's just a small amount of hand washing to remove the remainder. :)
I wouldn't use any type of thinners on the standard wheels as they are painted silver with a clear coat unless you want to make a real mess of them. ;)
As for the bug and tar remover it's a little co**** for removing the grime off your wheels. I wouldn't use it on my car any where. Scratches like fine sandpaper and have seen the results on many cars that I've had to correct ;) :D
    2. 1
    3. 0
      Tyre Sale Specials
    4. 10
      Android auto
    6. 0
      Remote start
    7. 1
    8. 1
    9. 10
      Android auto
    10. 10
      Android auto
