constant 12v power source
xCalibur_
I'm looking for a constant 12v power source. Like a noob, I'm going completely blank as to where I could get one. Any ideas ?
Note: not looking for a 12v that is activated by ignition.
got a set of foggies. which require a constant 12v and ignition 12v to activate a relay. ignition is easy. constant, not too sure.
yeah ciggie lighter is fine, ive connected mine like that.
plug on the left connects to the fog light harness
white wire is ignition 12v
red is constant 12v
green plug goes to switch
black wire is ground
then theres the fuse and relay
post-22021-0-51172600-1380955764_thumb.j
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
