Check your Stats!!!
Power at Flywheel (BHP) : 134
Weight without Driver (KG) : 1350
Power to Weight Ratio (BHP Per Ton) : 100.85
0 - 60 (Secs) : 10.24
0 - 100 (Secs) : 32.87
60 - 100 (Secs) : 22.63
Quarter Mile (Secs) : 18.70
Terminal Speed (MPH) : 75.43
Drag Strip Quarter Mile (Secs) : 18.50
Drag Strip Terminal Speed (MPH) : 76.66
fear me :ph34r:
What my corsa was!!!
Power at Flywheel (BHP) : 197
Weight without Driver (KG) : 1000
Power to Weight Ratio (BHP Per Ton) : 200.16
0 - 60 (Secs) : 5.70
0 - 100 (Secs) : 14.25
60 - 100 (Secs) : 8.55
Quarter Mile (Secs) : 14.10
Terminal Speed (MPH) : 99.46
Drag Strip Quarter Mile (Secs) : 13.90
Drag Strip Terminal Speed (MPH) : 101.26
stock sportivo:
Power at Flywheel (BHP) : 189
Weight without Driver (KG) : 1224
Power to Weight Ratio (BHP Per Ton) : 156.89
0 - 60 (Secs) : 6.89
0 - 100 (Secs) : 18.01
60 - 100 (Secs) : 11.12
Quarter Mile (Secs) : 15.30
Terminal Speed (MPH) : 92.17
Drag Strip Quarter Mile (Secs) : 15.10
Drag Strip Terminal Speed (MPH) : 93.77
Power at Flywheel (BHP) : 150
Power to Weight Ratio (BHP Per Ton) : 112.89
0 - 60 (Secs) : 9.22
0 - 100 (Secs) : 27.68
60 - 100 (Secs) : 18.46
Quarter Mile (Secs) : 17.67
Terminal Speed (MPH) : 79.89
Drag Strip Quarter Mile (Secs) : 17.47
Drag Strip Terminal Speed (MPH) : 81.21
How come Bigbum and Runx's cars are so heavy? Is it because of big sound systems or something else?
Here are my stats (I input 105kW to allow for intake and exhaust mods):
Power at Flywheel (BHP) : 140
Weight without Driver (KG) : 1176
Power to Weight Ratio (BHP Per Ton) : 120.96
0 - 60 (Secs) : 8.67
0 - 100 (Secs) : 25.58
60 - 100 (Secs) : 16.91
Quarter Mile (Secs) : 17.13
Terminal Speed (MPH) : 81.83
Drag Strip Quarter Mile (Secs) : 16.93
Drag Strip Terminal Speed (MPH) : 83.21
My stock ascent (based on the one dyno run I've done - so expect it to be lower)
Power at Flywheel (BHP) : 115
Weight without Driver (KG) : 1225
Power to Weight Ratio (BHP Per Ton) : 95.38
0 - 60 (Secs) : 10.80
0 - 100 (Secs) : 36.37
60 - 100 (Secs) : 25.57
Quarter Mile (Secs) : 19.28
Terminal Speed (MPH) : 72.81
Drag Strip Quarter Mile (Secs) : 19.08
Drag Strip Terminal Speed (MPH) : 74.00
Power at Flywheel (BHP) : 207
Power to Weight Ratio (BHP Per Ton) : 171.83
0 - 60 (Secs) : 6.39
0 - 100 (Secs) : 16.15
60 - 100 (Secs) : 9.77
Quarter Mile (Secs) : 14.78
Terminal Speed (MPH) : 95.64
Drag Strip Quarter Mile (Secs) : 14.58
Drag Strip Terminal Speed (MPH) : 97.32
Gotto love those quarter mile times :lol: If only you could convert that into reality :P
im a  little confused i put the stock stats in for the sportivo and i got different to what spec black got
how does that work
maybe im not using it properly
Just out of curiosity, I put spec black's numbers into the calculator and got the same results as he did ... do you have a slightly different horsepower or weight number, perhaps?
i probably put in the wrong stats my bad LOL
it seems fairly accurate but hey
i like it LOL
Yeah, its pretty cool, but I think, as Silva was alluding to above, it seems to flatter the wagon just a little bit! :P
take your spare out to save a tiny bit of weight.
Some of our cars will need more than the spare removed! :D
Actually, my personal "spare tyre" could remove itself whenever its ready. :P
Edited by Buddha
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
