Hi peeps...don't know where to post this, but as the title suggest is there a way to clean the inside of the headlights???
My headlight seems to be dirty inside. I've cleaned the outside throughly, but there seems to be a smudge from inside.
And thoughts or help inregards to this? Is it even possible to open the headlights?
Cheers
Cheers
Unless u pluck out the blubs and go at it with a bit of wire and some cloth tied to it. the only way is to put the entire pod in the oven or use a heat gun to weaken the glue that holds it together and rip it ope but be very very careful or u'll melt it!
You can always use a stanly knife/ scalpel to open up the head light.....clean the lense and then use a strong silicon glue to reseal the head light up!!
is this words coming from some1 thats done this? =D coze im gonna do it if uv done it runx :lol:
what i did:
1) Take off the headlights (unplugs the bulbs) then fill it up with water n pour some of those glass cleaner chemical in
2) Shake it around and leave it for 5mins
3)MAKE SURE YOU LET IT DRY before putting them back.
done :)
this is probably the easiest way.
goodluck
what i did:
done  :)
goodluck
Hmmm...that sounds interesting...I might give you way a go.
Is it hard to take the physical head light off from the car though???
Taking the light bulbs is easy, but don't even want to try taking the whole headlight console coz it seems complicated and I dont want to put it the wrong way?
to take off the rolla head light :ph34r:
----> tooo much trouble
from the looks of things you have to take off the front bumper
im not really familiar with the rolla headlights.
but on the camry, they're pretty simple to take them off. unbolt 3 bolts and you're done.
hope someone else can help you out... :)
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
