Pinging paseo
Hey all,
Just a quick question
Something that's been bugging me since I bought my EL44 paseo quite few years ago.
Basically it use to ping a lot
My friend suggested running 98
Even though manual says 91
98 prob gonna stuff my cat tho
A lot less pinging. But on really hot days. Still pings badly up hills.
Also for long time the plugs have been frosty white. Lean I guess.
Just wondering if anyone has this problem too. And has anything to suggest?
Even when got timing belt done awhile ago didn't help. Due to be done again soon.
I know my mums starlet does ping too on 91
Haven't checked her plugs tho.
Think they were an ok colour last time I looked.
Is it common for 4efe and 5efe engines to do this.
Strange that it'd be pinging on 91 as 5EFEs should be perfectly fine with normal unleaded (not E10 :P). And 98 won't kill your cat at all.
Thanks for the quick responses
What plugs u suggest I'm running Ngk
BKR5EYA ( v cut electrode ) 1.1mm gap
I've also tried Bosch platinum plugs they do same thing and go all frosty white.change them every 10 thousand Km's. yea might get someone to do the dizzy I have no idea with timing, thought the mechanic would've done that when they changed the dizzy o ring. Still leaking oil too :(
Sorry my bad they were talkin about leaded fuel in manual damaging cat.
  • 5 weeks later...
I put a set of cooler plugs bkr6eya plugs in. Same gap 1.1mm
Seem to feel a lot better now alot less pinging and plugs look healthier.
The hotter bkr6eya plugs the electrode would melt down after being in car for few 1000kms
Will post pics maybe sometime.
  • 1 year later...
finally think i sorted it
after doing some research online
read pcv valves can cause this when there faulty.
so i tried changing it + the grommet
seems ok now underload - uphills on hot days or with aircon on
doesn't do it anymore, plug colour looks more healthy too
no longer frosty white with melted electrodes.
just wish they would have changed this $12 part when they replaced my main seal
when they did the clutch
or when they did timing belt when they had to replace other oil seals
all new seals gone already because of the faulty pcv sigh :/
now all have to be done again got big oil leaks
      Stout Owners
    2. 12
      300 series turbo issues
    3. 8
    4. 55
      Stout Owners
    5. 2
      New Member
    7. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
