2006 Camry Altise
67wogval
Hi my missus owns a toyota camry 2006 model. The car has been perfect and no trouble at all. Just recently though the rear left hand door isn`t locking or unlocking when activating it with the key remote central locking. It almost seems like nothing at all is happening, you can`t even hear the solenoids moving inside the door. All the other doors are working fine and as per normal. Im about to remove the door trim to try and have a look to see whats happening. I already tried spraying some rp7 into the locking mechanism but that didn`t change anything. Does anyone have any ideas?
My other question is how do i remove this type of door trim? I already popped out the plastic behind door handle and removed that screw, but what else do i have to do, i don`t want to damage anything. Also i could see behind the door trim, in far left top of trim, there is a white plastic electrical connector which isnt connected to anything, im thinking this could be the problem, its come dis-connected.
Problem fixed!!
It was the white connector block, i pushed it into hole in door and i heard it click and lock in, then the lock was working again with the remote, some how it came loose and dis-connected or maybe some one never put it in properly previously to us owning it. I didn`t manage to get the door trim of, i just pried it open, plugged the switch in and pushed door trim back in. Would be good to know though how the door trim comes of still.
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
