Posted (edited)
So me being careless, I assumed the Sportivo major service is done at 100k's (as is with many other cars) as opposed to 80k's, meaning I am nearing 20k's after from when I should have got it done (at the 100k mark now).
How should I approach this? I have my car regularly serviced (every 5-7k) so it has been running fine, but unsure of what to do once it hits 120k if I get it done now at 100?
Any advice would be greatly appreciated.
Thanks,
Danny
Edited by dannydn
Thanks Trent, just updated my original post to be more clear with my question
I personally would service it now and at 120,000KM. What is required on both of the services?
your accessory belt would most likely need to be changed. spark plugs, fuel filter, and your usually oil change with filter as well. might as well do the gearbox fluid too. use some mineral oil and change every 20k. its inexpensive and makes your box last longer
I would say get it done soon
Consider water pump and coolant replacement if they haven't been changed
my water pump at 220k was still ok, replace only if its leaking water. coolant can go for another 100k
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
