Aurion Driver Side AC Vent
JQRambo
Hi
I'm new here but have been reading various topics and threads by other users for years. My question is...how do I remove this AC Vent (Drivers Front). I have searched but had no luck. If anyone could help me before I attempt it and break something, it would be much appreciated.
Thanks!
I have a 2011 (MY2010) Aurion Touring model with a genuine sportivo lip kit =)
Is that the GSV40r?
It should be easy,
On the bottom of the trim under the steering wheel Collin both left and right side there is a bolt/screw, und do them both,
Then gently pull the trim off, then pull out the vent.
It will be firm but don't pull to hard you brake it.
It's pretty easy.
Ok I read your reply and I removed the bottom most trim under the steering wheel and then the smaller trim below the ac vent on the right hand side. I just sort of pulled it after that and it came out easy enough =) Thanks for the reply!
Rattling av vent?
Yes my centre one, well the one on the right hand side of the passenger, if it's fully straight bit rattle from the air coming out of the vent but I just push it slightly left and it stops
Hmmm they are easy enough to get out now that I've done some myself. Looks like plents of things can break in there too xD
But if you have a rattle, you can always try some felt tap....given that it isnt a loose/broken bit of plastic in the vent or anything
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
