power FC corolla sportivo
hey guys i just bought a power FC
I was wondering if there is still anyone on here that makes harnesses?
I was digging up old threads but they were from years ago
thanks in advanced
18 hours ago, trentmeyer23 said:
There is very little chatter about the Power FC at all these days.
They're starting to get a little dated, plug'n'play is all well and good (except in the Sportivo case of course) but there are a lot more aftermarket ECUs out there for less that are significantly more capable.
Kaizen Garage does an Adaptronic 440D based plugin board for the sportivo now.  Full replacement board that screws into the stock ECU case and even runs the coolant temp gauge properly without the need for extra temp senders etc
Edited by CHA54
Pic of the Kaizen Garage Adaptronic plugin, it has sides that can be broken off so it fits in both the wide and narrow 2zz ECU cases:
Edited by CHA54
Yes, powerfc is archaic in comparison.  USB connection to laptop, MAP sensor or MAF sensor, 4D maps, VE tuning, knock control, direct wideband input, etc etc etc
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
