Coilover question (Possibly broken)
ctate1
I recently found a set of BC Racing coilovers for my 95 VCV10 Vienta, and long story short my car was driven up a considerably steep curb (rear right wheel). Now about a week after this incident, my rear right wheel almost constantly scrubs when cornering, and appears to be sitting a solid 3/4 of an inch lower than the other 3 wheels. I'm wondering if maybe the coilover could have blown? Or maybe bent. I had to raise the rear right to make the car driveable again, but any information I could get would be amazing thank you.
Was the spring seated correctly when it was installed? Take measurements, if they are the same as the other side, you should have no issue.
Also, jack the rear of the up and check that the spring is not loose between the collars.
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
