Is anyone aware of any possible reason that the repair work on a airbag recall could possibly cause a rain water leak into the cabin under the passenger side dash? Or could there be no sensible relationship, in which case I will have to look for other causes.
The airbag recall is for potential metal particles within the airbag mount, so there should be no link between the two.
Thanks for that, but could the removal process itself create a leak ?
No.
Your best bet is to grab a torch, some paper towel, a garden hose and an assistant. Then start drenching all of the seals whilst the other person checks for leaks.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
