1MZ-FE Genuine Oil Filter
ZZT86
Howdy,
Anyone know if 90915-YZZD1 is the correct genuine oil filter/part # for the 2001 Camry V6 ? Is there a high capacity filter available & what part # would that be ?
Cheers all :)
Not a fan of Ryco. Z418 appears to go for about $9 ea & the ST version for double that again. Not sure I could get better if bought in bulk but I know I can get even better prices than these for the OEM if I get a box of 10 which is what I plan on doing. Not sure my local dealer is willing to party otherwise the net will provide what I'm after @ a great price.
I will check with my parts man for details.
Ryco reference number is Z418; Z418ST for a longer life filter.
If you are wanting a higher capacity filter, I would check the specifications/dimensions for Z418 and then search the Ryco Catalogue based upon the filter's thread 3/4-16-UNF-2B
http://www.rycofilters.com.au/catalogue/dimension
Best to make a list of likely possibilities, then visit SuperCheap or AutoBarn etc for a visual filter and price check.
Looks like you are as price sensitive as myself. Sakura oil filters @ $5.65 @ Sparespro.com.au
Orders over $100 are free delivery. I have used this seller and had no problems with the Sakura oil filters.
http://www.sparespro.com.au/oil-filter-1150106001-z418-z87a-z422
I get what you guys are saying & I'll suss it out for sure but my theory has always been Toyotas are great because of the quality of the sum of it's parts & mechanically I like to use oem parts where ever possible at the best possible price of course ;)
Managed to get a box of 10 genuine Toyota 90915-YZZD2 (the correct part#) for the 2001 MCV20R @ $105/box which I'm pretty happy with.
Also bought some oils & Ryco parts for a power steering & ATM flush & refill from these guys - http://www.alliedautomotive.com.au/ @ good coin too ;)
Edited by ZZT86
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
