Corolla T-Sport through some mountain passes
Hi Reece, I've been trying to reply to this post, but for some reason the site wouldn't let me. On one of my morning walks, with my dogs, there is a Hi Lux tub sitting on the nature strip. I know nothing about it, except that I think the owner could well sell it, but hasn't. I will attach a photo for you, and if you are interested I will email you the address, if you PM me with it. Note that it is in Geelong, Victoria, maybe a good reason to visit. . Herb -
Fitting on the headlight bulb appears to be the usual twist to release and lock. Definitely do not try to brute force the removal because you will definitely break something like the headlight housing. Suggest that you use some WD-40 and have a real good look at the existing bulb using a mirror and a good light source. Then have a few wiggles attempts to loosen the existing bulb so it can then be removed. If this does not work, then time to be smart and not stubborn. Far better to pay a $15 fitting fee than the exorbitant cost to replace a damaged headlight assembly. -
help with clutch
High mileage camry
1981 Hiace ignition upgrade
Aftermarket Air Intake
Hey all, Just recently bought a 2007 TRD Aurion and am trying to find an aftermarket Air Intake, but am coming to the realisation that there is a very limited market for TRD Aurions. So far the only system I've been able to find is a K&N Typhoon Intake (link here: https://www.carmodsaustralia.com.au/KN-Filters-69-8611TS-69-Series-Typhoon-Performance-Air-Intake-System-Camry-35L-07-11?cq_src=google_ads&cq_cmp=18898892770&cq_con=&cq_term=&cq_med=pla&cq_plac=&cq_net=x&cq_plt=gp&gad_source=1&gclid=Cj0KCQjwpZWzBhC0ARIsACvjWRP893VLnAQsxIZJjcW5Go75b_T2N25rSWBVu6IeDziM2v41bpeyOREaAg1fEALw_wcB), however when viewing specifications for the product it states it fits Camry's from 2007-2011. Further digging revealed this product is an import from the USA hence why it's for a Camry - they don't have Aurions there. I am aware that they both share the 2GR-FE engine so I'm assuming the product will be able to be retrofitted to my TRD, provided the throttle body intake is the same diameter across Supercharged 2GR-FE's and N/A 2GR-FE's. Has anyone else in Aus had any luck sourcing/fitting one of these K&N Intakes, or know of another brand that do them specifically for the TRD Aurion's. Pretty confident in just ordering the aforementioned kit but their return policy sucks (can't return and refund if packaging has been opened, etc). Cheers guys! Jason.
