High idle when warm
Hi new to this forum. I have recently bought a 2004 corolla sportivo. When I first start the car it idled around 950 rpm. As soon as it is warm it idles at 2000rpm.  What are your recommendations?
TIA
I would start with checking the accelerator cable assuming it has one. Next would be cleaning the Mass Air Flow sensor and throttle body. Also check/clean/replace the air filter. Further down the list would be to consider a clean of the fuel injectors.
Thank you, I will check and clean and see how I go. Also I noticed the battery is indicating that it needs recharging. Apparently it's only a couple of months old but as the old owner said he has only done 4,000 kms in the last 2 yrs. Most of that time it was sitting in a garage.
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
