G'day,
Just picked up an Avalon MkIII GXi. I own 4 Fords, but worked around Avalons 2001-2006 at a taxi depot, so always had a soft spot for them etc.
Have an interesting starting issue with a workaround I found.
Has anyone ever heard of issues with the ignition switch on these? Igniter? Crank angle sensor? Knock sensors?
It has had aftermarket keys for 5 years now. The light goes off instantly upon insertion indicating it has been programmed as a master.
Now, it will just crank endlessly often. The workaround is to leave the ignition 'ON' for 5 minutes and then it starts no worries until the next time. Any ideas?
On 9/9/2017 at 9:16 PM, trentmeyer23 said:
Is the fuel pump getting power during this?
While I haven't tested the fuel pump during cranking, it does run very well and there is no buzzing which usually indicates a failing fuel pump.
I believe I've narrowed the issue down to Crank Angle Sensor or Ignition Switch. I believe it's the former and will change it this week.
Interesting that it will always start if the key is left 'ON' for a few minutes, almost like it primes the faulty sensor(s) or resets itself somehow.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
