Hi all,
i was driving along tonight and noticed my driver side headlight was not on, figuring it was blown I decided to get a new bulb and try to put it in, on further inspection I have discovered that the socket the globe plugs into has partially melted and needs to be replaced, I've tirelessly searched google to find a replacement source but can't seem to find one anywhere.
Where should I go to get a replacement socket?
its an 09 Camry and takes standard h7 gloves(it's the normal headlight beam)
Same thing happened to my mum and it cost her around $100 to have auto elec come to her house and replace a bit of the wiring just before the plug and the plug on both sides
Go to a wrecker and cut one off a donor car and do some minor surgery. Are you handy with a soldering iron ?
Will probably cost no more than around 10 bucks.
Just make sure to wrap the join with electrical tape  or heat shrink to avoid moisture and possibility of a short to earth.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
