Sydney Monthly Meet - 29th July - Last Sat of July at Villawood usual spot
Where is the remote receiver on a 1998 Camry
Hi legends, I recently bought Camry 1999, and I'm trying to repair everything I can. Car came with one fob (famous unbreakable thingy, with button cover gone and flat battery of course). I have managed it to open and I choose the way to put the battery out of the pins - done, without breaking it. I bought CR2032 and put it into a place. Nothing, nothing happens while programming mode activated. Battery is in contact and button seems to be working fine (you can hear clicking). Then I simply gave up and tried to looking for new Integration Relay... one day I met bloke explaining him what am I after and he told me he has 1 fob at home but its from Corolla. OK let's give it a try. I set car into programming mode and after the procedure 3x on/off, etc... I got flashers slowly blinking but only 2 times. I started to getting happy 🙂 but at the end Corolla fob does not work at all, but at least I got some response from car... Any ideas? I want to avoid buying a new fob for 100$... Cheers! Martin -
1987 Toyota Corolla - 60 000km on the clock
Hi All I have a 1987 Corolla with 60 thousand kms on the clock. Immaculate condition on the inside, starts first go and all original. Looking to sell. What would this be worth? Thanks -
Toyota Landcruiser problems
13
300 series turbo issues
55
Stout Owners
13
8
55
Stout Owners
Hi Jamie I've just bought a lite stout a 63 it has 13s as well but they tell me they are to slow so thinking I'll do 15s or 16s
