Need help on changing fog light globes
Part Wanted for 80, 100, 105 Series Landcruiser Spring Cap
Hi, I am trying to obtain the part pictured, it is called a Spring Cap and it is spot welded to the chassis, called either a Spring Cap or Rear Spring Bumper Unit, the bump stop attaches to it and you can see it neatly inside the rear spring, this can be left or right it has no orientation, I want to buy either new or used. I have tried on some other forums and also many, many wreckers, it is hard to get at so wreckers don't really want to get involved, I was offered one in an 80 series and I could take it out myself for $20.00, Bargain, but they would not allow me to put the wreck on its side to access it and after surveying the job decided I could not do it in the position it was in, is there anyone who wither has one, knows where I can get one or has useful information to help in me finding one, I am happy to pay postage or even drive a bit of distance to remove one from a chassis I can get at? any help appreciated. I am in North Lakes Qld, 35k North of Brisbane. Graeme power -
2016 Aurion Sportivo rear speaker removal/replacement
Hello again One of the rear speakers in my aurion has begun rattling and needs to be removed/replaced. Does anyone know how to get access to the speaker to replace it and does anyone have any recommendations for replacement speakers. it is the rear left speaker under the larger cover. Thanks again -
2016 Aurion Sportivo missing electric blind button
Hello everyone, Ive just bought a 2016 Aurion Sportivo and was wondering about the electric blind/sunshade button. The car seems to have the hardware for the blind itself (I think but I could be totally wrong) but the button is just missing, with a hole in its place. Does anyone know if it would be as simple as buying a replacement button? I’m not sure what the cabling for the button looks like so I can’t guarantee that the cables are there, though I would assume they are since it seems the actual blind hardware is there? Also, does anyone know what I should do with the other missing button (lane departure switch) hole. Any help would be appreciated -
88
Aurion 'Pull Left' Issue Explained
Hello all, I've just picked up a 2006 Aurion that failed a RWC .. one of the things it's said is needed is caster bushes 'front' Reading this thread seems like it would be a good idea to upgrade at the same time. Is there a how to on changing the bushes for the keen DIYer? Much appreciated, Cheers,Tim -
They may not choose to insure you, but there's a budget/low cost insurer you could check out They'd only offer 3rd party, but maybe worth a go https://www.essentialsbyaai.com.au/ -
Rear power door
Hi Alim, just open your glove box and the button is on the side, you can't miss it. If you don't see a button then you don't have a power tail gate. -
Stereo upgrade
Does anyone know if any antitheft protocol will activate if I remove the original stereo to upgrade to a multimedia head unit? I have an 06 Kluger CVX, a pretty basic model with not steering wheel controls or anything like that. Cheers. -
Turboed Corolla Overbuilt?
MN: ZZE122R Engine: 1ZZ-FE Hi, I'm currently in the final stages of researching about boosting my car which I'm finding is incredibly expensive but oh well car people aren't sensible people. I was looking to make this car a sort of daily but take it to the track and car meets. Anyways I was just looking around at other forums and I couldn't find any that described the type of mods required for a certain power level as I don't want to spend a heap of money when I don't need to however I want to make it kinda reliable so idk. My power goals are between 275-350hp running E85, here are the engine internals I want to upgrade: Monkey Wrench Racing (MWR) 1ZZ-FE Engine Rebuild - Forged Rods, ARP Main and Head Studs, Ported, Upgraded valves, stock 10:1 CR Turbo - GTX2860R Fueling - MWR Injectors 630cc, AEM fuel Pump 340lph, (might do flex fuel), Intake - Billet Centre fed intake, Haltech DBW conversion Boost control - (I'm not too sure what to buy) Intercooler - (Anything that'll fit) I hope I wasn't too vague, I was asking a tuner in my area called Tunehouse (lovely people btw) and all they said was you might have to run a bit of boost so I'm not too sure how to interpret that in this context. Any advice will help, thanks. -
8
2ZR Turbo
hey mate, car is back on the road. been daily driving it since may. issues that i currently have are fuel leak, afr gauge not working and no boost in first. fuel leak was a result of me removing the fuel pump to see if i upgrade the stock one. still need to diagnose afr gauge as the rest of the sensors from the multi gauge work. worst comes to worst, i will just run a separate afr gauge. no boost in first should be fixed by tune. car still is currently untuned but hoping to get that done before the end of the year. havent had any issues with police so far. driven past a few highway patrol cars and normal police cars. my car isnt really red hot however intercooler is quite visible. just dont hoon and my guess is you should be fine. i will eventually get an engineering certificate for the build just to save me the headache in the future when dealing with police
