will these fit?
XploShun
probably means the rims are available in either +38 or +45 offset in a 7" rim. There's plenty of offset calculators on the net for you to compare your current rims to the wider rims for the purpose of clearance estimates. Basically the higher the offset, the firther in the rim sits, but you have to take into account the difference in rim width when comparing to the original wheels.
ooo icic!
now have my eyes on the sa90, its
16×7.0JJ 36 4H-100
the offset is 36... does that mean.. its too close inside????
i just found 2 offset calculator site..
whats the Wheel Width for our stock wheels?
if it fits the 2zz does it mean it will fit the 1zz???
and also.... question about center caps....
are they worth it??
does it come off really easily? can people just take them off with their hands?
i mean.. they r like at least $100 for a set of 4... rims have lock... do these caps have lock as well.. :huh:
Edited by XploShun
ive used the offset calculator that xoom posted
used the stivo 16x6JJ 45 as original (i still using the 1zz stock wheels, no idea about them)
and
16×7.0JJ 36 as my new wheel
it says:
The clearance from stut housing to the inside of the wheel will be 4mm LESS
The outside edge of the wheel will EXTEND an extra 22mm
so whats does the 1st one mean???
and also.. offset calculator... y didnt they ask for the wheel size.. like 16 or 17 and stuff
do u guys know what happened to the sa90 forge?? its not on wedssport homepage anymore..
here is the other topic http://au.toyotaownersclub.com/forums/inde...?showtopic=8212
forged was sa90 i think you should get the limited edition on any toyota.
Edited by kcorro
hmm
whats so special about the bandoh?? (just did a search on their homepage... their race queens are HOOOOT! hahahha)
do they cost the same?? lighter? or what??
btw.. what does
mean??
kcorro... did u have these on? 16×7.0JJ 36?? its ok? no scrapping and stuff...
Edited by XploShun
im goin to ask about the limited edition one...
but... that pic shows its a 5 stud rim...
do they have it in 4s???
if im buying.. im gonna buy the wedssport nuts too.. a set...
center cap.. its too expensive... .. but if they have bandoh x wedssport center cap... i can think about it... :lol::lol::lol:
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
