Posted (edited)
how the hell do u set the shift point??. ive set the brightness of the lamp but cant do the shift point!!!!
most of you will say, look at the instructions.... i have, but cant understand it, simply because its not in english!!
help!!!!
*****EDIT EDIT EDIT*****
due to a few members requests, ill a few tips on how to set up 1 of these things.
PIVOT SHIFT LAMP SSL-X
more info- http://pivotjp.com/product/flame-shiftlamp_top-e.html
first off, the shift lamp can be hooked up in to ways, the cig lighter and signal wiring.
anyway, i decided to just plug it into the cig lighter.
before you do anything, have a look at the back of the little black box. make sure the the white switch is moved "to the left, to the left". NOTE for some reason, if its to the right, the light will constantly be on.
BRIGHTNESS SETTING
when you first start the car, the lamp will light up for a second or two. to set the brightness, simply press "LAMP". the light should remain on. to adjust, press lamp again to go dimmer or "SHIFT POINT*" for a brighter light.
SETTING SHIFT POINT
when the car is running, press and hold "SHIFT POINT*". the light should then start blinking . when it blinks, you can let go of the button. rev the car (in neutral) to the desired rpm. hold it at that rpm then press "SHIFT POINT*" and hold until the light goes off.
once this is all done, go test it out! haha woot woot!
don't forget to mount it in a nice location. i find that sticking into the top of the aircon vent is perfect.
thats all for now. big thanks goes to GReddy ES for getting me the shift light and giving me few pointers in setting it all up.
Edited by x_tarcy33
its the x model. mods, please close this thread. ive worked it out!
Well, tell us how you did it. To help out future people :toast:
so if u wanna set it at 8rpm u have to rev it to 8rpm and hold it there??? :ph34r:
yea, its only for 2 seconds tops
Posted (edited)
glad u figured it out dude..and wow thats one bigass shift light..hahha..better pray it doesn't start to iritate u!haha enjoy it!nice write up too!
Edited by GReddy_ES
      Android auto
    2. 0
    3. 0
      Remote start
    4. 1
    6. 10
      Android auto
    7. 10
      Android auto
    8. 1
      Turboed Corolla Overbuilt?
    9. 3
    10. 3
