Air cond FILTER
robbyj
Daughters got a 2010 Prado.her service through Toyota told her that her air con FILTER needed replacing or cleaning..Where is thios filter please??
Is it the inside air filter form the bonnet air vents into the cabin instead ???
Robby J
so its the air filter from the bonnet air inlet behind the glovebox  and NOT a A/C filter ??? My Falcon s also behind the glovebox. Where can i look for instructions on removing/cleaning the filter please ?
I would assume they are referring to the cabin air filter behind the glovebox as the receiver dryer in the engine bay can not be cleaned. There probably aren't any instructions on the removal process.
Most most modern Toyota gloveboxes are easily removed by squeezing the sides in whilst pulling it open.
    2. 0
      Has anyone found 200 Series Rear Screen Delete Cover in AUS
    3. 11
    4. 1
      2007 - floor mats
    6. 0
      2002 Hilux Engine Replacement
    7. 3
      Engine conversion
      Po299
      Boot Dimensions?
    10. 1
      2007 - Floor mat
