Japanese Import Toyotas to OZ & NZ
Hi We have 2014 Prado 150 series diesel which has done 304K kms. Serviced regularly. Timing belt done at 300K. Wanting to give to relative but don’t want issues for her. Is that number if kms going to be an issue. Or do you know of anything else which could be. Dianne TCB -
Most likely culprit would be an intermittant Suction Control Valve on the HP Pump. I also wouldnt rule out some FOD in the Tank...Like a piece of plastic floating around in the tank and blocking the pick up -
Bailey's Injector group..They DLC more than just the shaft like the stock Denso injectors. Run a 2 or 5 Micron Secondary Fuel Filter. This will make the Injectors last well over 400K if you change both the Filters regularly. Be very very careful when reading + injector values.. More times than not the ECU is compensating for a lazy Pot If the Engine has no EGR delete then the Intake will need cleaning, and normally it's Pot 4 that suffer first due to a less than tuned intake and the preferred intake airflow path -
1VD - Ticking Noise
Cracked Rocker..Its been known to happen. Inspect the Roller Rocker arms. This Valve Train has a roller rocker Hyd. lash adjusters..If it ticks then it's either a cracked rocker arm or less likely a buggered seal in the lash adjuster -
More likely the dealer has not cleared the Maintenance when done. I assume you have already had at least 1 service? -
5
This is a Genuine Pump. I have purchased one of them and they are the real deal..Only $204 https://www.ebay.com.au/itm/193423510411?itmmeta=01HZKTGWM45A0T8344CT9FDJE1&hash=item2d08f08b8b:g:kl8AAOSwNIdjvhes&itmprp=enc%3AAQAJAAAA0HhqVFSyBnU7PEsPNMQZxkkyoA4eM0GttJtcLihIarD%2BAFiXMRernfQR9%2FxzyNVxz%2BxslUSxn3pvysuEuiUGoQBoIkEy4xO0mEsSBj4i8yJ%2F3ah3SOn2PoXoE5dvE0Q386%2BK5GC7fw4Mlvxb1iCYrRCBvoOhOZZkpp%2BsRIZ4KWxGNHWaevcjlwEjgmPEHPqxNnJuxlfj6GYyh9N%2B7o%2BBZC7eIP%2BpOfuuIkwjEPi7vVI3woVVQ6uqQUq0uOXQxKopQ%2BaZlbuYuAKvnVbwDjd8oso%3D|tkp%3ABk9SR6jKw_r8Yw -
Nice Car. Is it still forsale? -
Ae92 genuine low ks 70800
Is this your ad in Gumtree? 1989 TOYOTA COROLLA CS SECA 5 SP MANUAL 5D LIFTBACK, 5 seats AE92 | Cars, Vans & Utes | Gumtree Australia Pine Rivers Area - Lawnton | 1325274871 If it had been like my previous Toyota Seca SX hatchback with the 4AGE engine, twin cam 100 KW which was a pocket rocket then I may have had some nostalgic interest but always the $$$. -
BATTERY in Klugar 4 years old
This indicates that the battery is getting due for replacement. As a general rule expect 3 to 5 years for the lifetime of the battery. There are a few posts about what batteries members have selected in the past. Recommended Century battery models are NS70LX MF and NS70L MF for Toyota KLUGER. Last battery that I purchased was a SuperCharge brand truck battery model MF80D26L which will also be suitable for a Toyota KLUGER. Just happens that my other Century battery which is 5 years old is currently being recharged so considering whether I really need to get a replacement. -
Hi Jeff, Try your local brake and clutch shop. If you can take your old one with you. Herb
