Are the brakes gone already ????
xoom
Hi All,
Noticed for the first time today when i went for the brake pedal was doing under 20kmph that i heard this reasonably loud grinding noise from the front end of my car. :blink::blink:
Now at first i thought i was imagining noises due to all the other noises in my car and then at the next set of lights same result.
Mind you this only happens when im on the brakes to slow down.
Could it be that after only 23K km that the brakes have had it ?????
Have any of you guys changed the brakes already n at what k's ?
Bill
Glazing :blink::blink::blink::blink:
Never had this before and considering its already done 23K km's......
N did this just form over night ?
ok ill give it a try on da way home but if i hit the brakes n dont stop then we will know it wasnt glazing ;) ;) ;)
I have a rumble when coming to a stop from around 20kph (intermittent) and I also have the shudder (warped fromt discs).
There is a link to bigger brakes 1 or 2 pages back.
I'm currentley investigating a brake upgrade for the stivo (save for the $3500 systems),
and will post more info (incl prices and avail) soon.
The setup could be using celica discs (even thou they are 5 stud)
I'm aiming for a decent upgrade for less than $2k.
Ive had the calipers off, and there clean pads in there.....
I'm actullay thinking thr grumble in my front right may be a wheel bearing perhaps.
Doubt it would be a wheel bearing after 23000km, unless you've been doing a LOT of track driving...! :P
I covered 45k km so far and had 3 sets of brake pads.
Now I have to change front rotors (pay for it :( ).
Rear rotors were replaced 10K km ago under warranty.
Will now buy EBC Greenstuff pads - hope they last longer than stock (15k km)...
imek have they given you a quote ( $$) for the new front rotors ??
      Bluetooth stopped working
    3. 3
      Corolla Seca For Sale
    5. 2
      Toyota Corolla Sportivo
    8. 2
    9. 1
      Toyota Landcruiser problems
