Got a little problem with my Stivo
after installing my sri
i noticed a little lag in the rev range between 4500 - 5500 rpms
it was fine when i had the stock box but after installing the sri it started happening
does this happen to any1 with a cai or sri?
should i reset the ecu or is it the sri?
cheers Denz
cheers Denz
didn't you take out the battery to remove the stock airbox? coz if you had the battery out for more than a few mins, it would have reset it. Just drive it the car around for a little while to see if the ECU adjusts.
Maybe due to the engine bay heat!!!!!!!!!!!!!
or otherwise known as heat soak.
Denz i would say do a ecu reset. you should do one after every mod
yeah i did all those things
disconnected the batt a few times a drive it like i always do
it seems normal only when i rev up to the rpm range that it happens
ill maybe try reset it again then see what happens
that for the help guys
cheers Denz
cheers Denz
oh btw, does it happen when the engine is cold or only when it's warm?
Air flow meter dirty?? if your car is hesitating a bit...like have a black spot when reving the car then its your air flow meter that doesnt like the extra air comming through...correct me if im wrong.
      overheated engine
    2. 1
    3. 62
    4. 1
    5. 1
    6. 0
      Tyre Sale Specials
    7. 10
      Android auto
      Remote start
    10. 1
