howdy folks, new camry owner here, 2000 conquest v6 manual,
didnt come with a keyless thingey so bought one from toyota, 40 bucks.
have tried turn from lock to on 3 times & leave on then push keyless
thingey but nothing happening.
help anyone much appreciated ta joe
Did you have ir programmed??
:lol: ^^
yeah did you Toyota programmed the key with your car? if you only bought it and walked away from the shop, then the keyless/remote is pretty much useless :P
there's a few DIY on how to programmed the keyless/remote. ;)
No i just asked about it and the toyota guy sold it, just said look in the book which i have done but the car or the whatsit doesnt respond, where do i find more info? thanks
From the Camry Owners manual(Page 10): If the remote control does not work, resynchronisation ma be required. To resynchronise the remote:
1.turn the ignition switch to "ON".
2.Press door lock/unlock button on the remote control.
3.Turn ignition switch to "LOCK" and remove key.
4.Test operation of RC.
If that doesn't work, see your Toyota dealer.
Hope That helps..
You'll most likely have to disconnect the central locking module to re set it... I can't remember how long for...
Try 15 - 20 seconds...
The module is usually located behind the glove box but if you can't find it, just disconnect the bettery for 15 - 20 secs and try programming the remote again with the 3 turns of the key...
Posted (edited)
As I understand it, Toyotas use a rolling code security system which means the code is changed each time the car is started/opened and if the remote loses sync with the car's system then it won't work, hence the procedure outlined in my previous post. The rolling code system is designed to prevent sitting nearby and obtaining your car's code using a remote scanner. If you have purchased a new RC then it will not be synchronised with the car and will not work.. If it still doesn't work you will have to take it to a dealer..
Edited by Topdog
$40 for keyless system??
i've never heard toyota offers it seperately
any more info??
thanks
I got the remote for my 98 camry, costs $30, another $30 to program it... (total rip off! there's plenty of DIYs on the net)
Any luck? What works?
btw... i just purchased 2 extra remotes... the toyota rep told me you can have up to three remotes programed...
just that when you do the key to on two or three times you have to press the remote button simulationously... havent tried yet... still sitting in glove box
Can anyone shed light on these "pleanty of DIY's on the net" please. I am not sure if the 94 Csi came with remote central locking, but I guess i would be prepared to try if i knew how to program the remote
I remember this coming up on Camcrew once... ask LittleDavey83 on Camcrew and he'll be able to tell ya if needed.
That procedure ^^ from what I know works...
Program remote:
1) Turn the key to ACC (3 times , as quick as possible)
2) when you have done this right, the Security light will light up longer than usuall
3) press the remote button, if you have 2 remotes you need to press them one after each other. Otherwise one of them will not work. so do all key remotes in one procedure. If it is successfull I think the blinkers flash.
Turn off horn chirp:
3) press horn. it should chirp or flash the blinkers
This worked on my 99 Conquest.
Any ideas on how to program two stage unlock? I just tried it following the instructions in the manual but it just ended up cancelling out my remotes and thus I needed to reprogram both of them.
What do you mean 2 stage? as in when you press the remote onces it unlocks the drivers door only ?
If so then try this:
3) press the electronic door lock button on the drivers side door.
Im pretty sure thats the procedure. If it works the blinkers should flash....
Hope that helps
Your the winner pal, that was the key, disconnecting and reconnecting the battery and i'm in business,
Many, Many thanks, cheers joe
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
