Clutch and Flywheel
Taken from www.newcelica.org
CLUTCHES
Manufacturer: ACT
Product: Street Disc Clutch Kit w/ HD Plate
Part Number: TC2-HDOO
MSRP: 377.00
(MSRP is typically higher than most shop prices)
Description:
The ACT Heavy Duty Pressure Plate provides 44% more pressure over stock providing increase torque capacity, durability and longer clutch life.
Manufacturer: ACT
Product: 6-Puck Clutch Kit with Extreme Plate
Part Number: TC2-HDR6
MSRP: 407.00
Description:
ACT 6-Puck Clutch Kit with Extreme Plate Not recommended for street use due to harsh engagement
Manufacturer: ACT
Product: 4-Puck Clutch Set with Extreme Plate
Part Number: TC2-HDR4
MSRP: 387.00
Description:
ACT 4-Puck DIC with Extreme Plate
Manufacturer: Blitz
Product: Active Clutch Kit
Part Number: 65008
MSRP: 1150.00
Description:
~Blitz Active Clutch (chromolly) - 10.5 lbs.
The BLITZ Active Clutch was designed to hold maximum horsepower while retaining daily drivability. The Active Clutch is a complete clutch assembly that includes flywheel, pressure plate, clutch disc, and all necessary hardware. Our clutch systems weighs an average of 15%-20% lighter then stock. The unique feature of the BLITZ Active Clutch is the ability of change the clutch from a single disc clutch to a twin disc clutch. This allows the user to choose the correct clutch according to the power of the vehicle.
Manufacturer: Exedy
Product: Ceramettalic Clutch Kit
Part Number: EXD-16-900
MSRP: 399.00
Description:
EXEDY racing clutches with organic friction materials utilize only premium materials to provide maximum resistance to slippage and burst. EXEDY organic clutches can also handle modified engines due to the increased cla
mp loads. Drivability with EXEDY organic clutches is similar to that of stock clutches. Pedal efforts will be slightly higher due to the higher clamp loads. As with all EXEDY clutch discs, EXEDY organic clutches feature high capacity spring center dampers designed to reduce drive train shock and impact.
Manufacturer: RPS
Product: Max Street Clutch
Part Number: MS-22549-ST
MSRP: 446.25
Description:
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. Pedal feel is stiff to very stiff and engages smooth. RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technollogy allows us to create almost any clutch unit with any pressure ranging from st
ock to double stock in 100 pound increments.
Torque Cap: 300 Pressure Increase: +60%
FLYWHEELS
Manufacturer: AASCO
Product: Flywheel
Part Number: 449.00
MSRP: N/A
Description:
~AASCO (aluminum) - 8 lbs.
AASCO Light Weight Flywheels are designed to improve the overall performance of your import. The replaceable friction surface will allow you to do away with resurfacing your flywheel ever again. The high tolerance manufacturing insures a perfect hassle-free installation. The flywheel is designed for normal street use for the every day performance enthusiasts. These flywheels are manufactured from the hightest quality materials like 6061-T6 aluminum for the flywheel, treated steel for the heat shield (friction surface), and OEM quality starter ring gears. All flyweels come with a one year limited warranty.
Manufacturer: C-One
Product: Flywheel
Part Number: FF1340-ZT231
MSRP: 39.00
Description:
~C-One (chromolly) - 9.9208 lbs.
It is suitable in the sport engine
The lightweight flywheel which makes the light response possible.
C-ONE ƒNƒƒ‚ƒŠƒtƒ‰ƒCƒzƒC[ƒ‹, at the stickiness and strength of durability and the material itself for temperature variation adopts the chrome molybdenum steel which has established reputation, high balance actualizing high complete round characteristic at high working accuracy.
By the fact that substantial light weight conversion is assured in comparison with the genuine flywheel, as for the NA engine of course the large aerodynamic volume displacement car and the turbo car being, it can taste the light response.
ZZT230 ¥ ZZW30, M/T car of 1ZZ-FE loading
- Weight: Approximately 4.5kg
- Even in the sequential shift car of MR-S at the time of installation possibility & installation
Exchange of genuine installation volt/bolt is necessary.
Manufacturer: Exedy
Product: Lightweight Racing Flywheel
Part Number: TF01
MSRP: 375.00
Description:
EXEDY racing flywheels are made from billet chrome moly steel and are specifically designed to reduce weight and inertia for improved engine response. Most EXEDY models incorporate special design features to enhance the airflow for improved clutch cooling.
Manufacturer: Fidanza
Product: Flywheel
Part Number: 130131
MSRP: 478.00
Description:
~Fidanza (aluminum) 7.5lbs
One of the simplest way to free-up horsepower on a manual transmission car is to go with a light weight flywheel. Our Fidanza flywheel is state-of-the-art CAD designed, performance balanced, and tested in the harshest of environments.
A lightweight flywheel reduces the rotational mass at the transmission area and thereby "releases" lost power that was turning that old heavy factory Toyota flywheel! Faster reving, better launches and more top-end HP is achieved because the engine does NOT have to work as hard to move this lightweight flywheel!
Fidanza's lightweight flywheel is the ultimate lightweight flywheel for the 2ZZ-GE engine! Flywheel is approximately 45% lighter than stock.
Also, the center friction section of the flywheel is replaceable, so in the future when you replace your clutch, you can just change out the center section of the flywheel, rather than purchase a completely new flywheel.
Manufacturer: JUN
Product: Flywheel
Part Number: N/A
MSRP: 425.00
Description:
~JUN (chromolly) - 9.6998 lbs.
JUN 's flywheels have about 200% more strength compared with normal flywheels. It was made using Chrome-molybdenum steel. The power of inertia rotation can be decreased by reducing the excess weight, and therefore, its strength directly passed through to the high response.
Manufacturer: MWR
Product: Chromoly Flywheel
Part Number: N/A
MSRP: 389.00
Description:
Designed and produced to be the best available, MWR flywheels provide the performance and durability you're looking for at a racer price.
Features:
- Super lightweight at only 9.0 lbs.
- Forged single piece chromoly steel.
- Integral ring gear hobbed from the forging for precision and extra long life.
- All surfaces are nitro carburized, increasing the hardness to ~3x the OEM piece and preventing corrosion.
- Material is removed in non-critical areas only to maintain strength while reducing weight.
- Precision machined in Japan to exceptional tolerances - no balancing holes required.
- Resurfaceable, which allows for inexpensive repeated usage. Much less expensive than replacement friction faces for aluminum flywheels.
- Bolts to stock crankshaft and stock or aftermarket clutch with no modification required.
Manufacturer: RPS
Product: Billet Flywheel
Part Number: RP BF-225492
MSRP: 575.00
Description:
~RPS Billet (aluminum) - 9 lbs.
RPS announces a new line of superior billet flywheels. These flywheels utilize RPS's patent pending "segmented" heat shield system. Traditional heat shields warp because of the uneven heat produced by a slipping clutch. Just like a car going around in a circle, the outside tires go faster than the inside tires, the clutch disc slides faster around the outside of the flywheel than it does around the inside. The faster moving outside gets hotter than the inside. Because metal expands more the hotter it gets, the outside of the heat shield expands more than the inside. Traditional heat shields are made of one piece metal rings, so when the outside expands more than the inside, the only thing the shield can do is warp. The RPS Segmented heat shields are not connected so they can expand and contract without warping. A warped heat shield causes the clutch to slip, which causes more heat and more warpage.
RPS Billet Flywheels are dynamically balanced after CNC machining. Other flywheel manufactures assume that since they CNC their flywheels it comes off the machine fully balanced. This would be true assuming the density of the aluminum is constant throughout the part. Unfortunately even the best billet material is not evenly dense throughout and the starter ring gears are never perfect.
RPS Billet Flywheels are also fully rebuildable for the life of the car and can be up-graded to Carbon-Carbon at any time.
Manufacturer: Toda
Product: Flywheel
Part Number: N/A
MSRP: 450.00
Description:
~Toda (chromolly) - 10.3617 lbs.
TODA Racing lightweight flywheels increase throttle response and aide in overall vehicle performance. These are not modified stock flywheels, but brand new units produced from 100% chromoly steel. In addition to these flywheels, TODA Racing also offers high performance clutch packages which include a TODA flywheel, pressure plate, and disk.
Manufacturer: Unorthodox Racing
Product: Flywheel
Part Number: 061210900
MSRP: 486.00
Description: ~Unorthodox (aluminum) - 8 lbs.
Hope that helps some people out !
Edited by Danthuyer
what about Australian Prices and do people have these products installed?
Price??? That you'll have to chase yourself.
And as the topic stated no talk on toms/TRD which is what a few ppl have hear. Apart from Northy and screamin' whom have excedy and fidanza.
You really have to talk to the Celica owners in the States to get good ideas on whats what I'm affraid :(
Edited by Danthuyer
The Fidanza is good, doesn't change the sound of the engine on idle and startup.
flywheel changes the engine note on idle? :blink:
:blink: Now i am confused, i thought some of you guys here with lightweight flywheels said there was a different sound? Maybe i shouldn't have said engine :P but the sound is from the engine bay.
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    5. 11
      300 series turbo issues
      Any 2L motors for sale?
      Proud Owner of Toyota Crown
