International Student at Curtin University
hi l have a 2003 TOyota camry thats done 300,000km, l noticed sometimes but not often when l turn the steering wheel a hear a slight single squeak noise, maybe it happens once every second time l drive . l am getting it serviced in a couple of weeks to l will get it checked then, but what do you think is causing it, do you think its most likely a minor problem or could it be serious -
.I have 2006 very last 100 landcruiser Sahara. Mine brakes on front left and right going round corners for no reason. Not sliding replaced sensors/ front diff/ all new hydraulic shockers/ new abs system .Nothing shows up on computer when checked..Spent to $15000 and it still does it. Any one in Melbourne can fix it? -
4
Front Cameras
Can Camera's with Sensors be retrofitted in place of the sensors? -
51
Not ideal where you are but I would ry a couple of things: Either disconnect the batteries (both) and leave for a good 10 mins - enough time for all electrics to discharge.. Another one which worked for me was to disconnect the ECU - big plug on the passenger side firewall. Same thing, allow for electrics/electronics to discharge. Not practical for you at this stage but if you can get a Scangauge. This will allow you to clear the codes. Car has gone in limp mode. I had this problem several times whilst towing a caravan due to a performance chip which would cause a limp mode. No more as I have had the ECU remapped. -
51
Hi I have a 2011 landcruiser GXL I am experiencing this issue right now & stuck in Cocklebiddy. Can anyone assist please ? -
1kzte throttle body
Hi Simon, You could try this mob. Genuine Japanese Car Part Imports - Amayama I have found that they seem to have everything, and their prices are good. Herb -
Aftermarket parking sensor
Hi guys, I’m a long time Toyota owner, and am currently enjoying a 2004 Corolla Wagon with the 1.8 1ZZ-FE. The car starts and drives really well, however during warm starts (after sitting for 5 minutes) the car cranks for around 6-8 seconds before starting. It’s worth noting the following: - The car starts right away in the morning or if it hasn’t been driven for a couple of hours. - There is no indication of rough idle or fluctuations when driving - Outside air temperature doesn’t seem to make a difference I’m wondering if anyone has experience with this issue? I’m leaning towards vapour lock in the fuel rail caused by leaky injectors? I’d appreciate any advice or if anyone has had a similar issue with their car. Thanks very much in advance, Oakley
