black bonnet on 03 corolla
hey does anyone have an 03 model corolla with a black bonnet/ or carbon fibre oem style on their white car?
i just want to see what it looks like.
please post if you have pictures.
thanks.
vic.
Here's a couple:
So is that illegal or non road worhty?
just asking .... not stepping on anyone's tails. Cause I was considering it as well. Either that or put a scoop (small one) in the middle to get some air flow happening to the headers. Will the air friction slow me down if i put a bonnet scoope ???
Here's a couple:
Guni adding a scoop won't affect your overall aerodynamics over the front of your car. Well as long as it's not like so high that it starts to block your view :lol:
have a look on the TOC forums in the UK - search for a member called Ponzer. he has a compressor that he's had resprayed in white with cf bonnet - probably the best e12 in Europe!
Here's a couple:
Not a fann of over statement. As long as it works, won't mind a small scoop.
In NSW they're illegal,
(In an accident)instead of crumbling on impact it shatters into sharp pieces, rather dangerous.
I don't see the point in having them on a "street car" anyway.
You're better off getting the bonnet sprayed.
Edited by TRDYUS
They are? You've obviously checked brother. Last I heard they allowable with the bonnet pins.
It's important to note that I'd also spray the grille, and part of the eyelids black to match the bonnet lines. I doubt I'd go through with it anyway, probably a bit too rich for an everyday car.
The bonnet would go well with a set of black / polished Konig Unknowns though...
      Hi from Wagga
    4. 2
    5. 2
      Engine oil dipstick reading
      Landcruiser 13B Engine Swap
      Lock CH-R
