Which insurance company and how much do you pay for it?
2004 hzj79 surging/jolting
Gday Ive got a problem with my 2004 hzj79 with 235,000kms with no turbo, ive takin it to a few places all have different answers. At 1400rpm just on light throttle it seems to be surging/jolting as if your on and off the accelerator. Ive recently had the head gasket, head, injectors, fuel filters and timming belt all done and is still happening after the works been done. Has anyone else had the same problem before or be able to point me in right direction? Cheers. -
6
Australian customers gullible ?
Not sure if this thread is still active, but It's 2024 and nav is still a problem in my 2018 Prado. I paid for an update, but I haven't noticed any difference, maps are still out of date. I tend to use my phone, but I would prefer to use the existing screen. I think you're right, if enough of us complained or cared, maybe something would be done to improve this problem... we are customers and we paid well for it! Hopefully we are not a dumping ground for old tech! -
Gen 6 Cluster Backlighting Issues
Hey guys, I'm having issues with the gauge cluster backlighting keep blowing fuses every time I turn on my lights. I have tried cleaning connections, replaced the lights and even removed the dimmer switch. Has anyone come across this issue at all? -
Windows wont work after Jump start
Easy fix, OPEN your window, then CLOSE the window ( This time Continue to HOLD the switch UP for a further 10-15 sec ) Then reopen the window and once again continue to HOLD THE SWITCH DOWN for a further 10-15 Seconds, Shut her down, turn IGN back on Window auto function all reset, no probs, Leave the money on the fridge Cheers CONROD- 1
Faulty speedo
Remove dash instrument cluster, remove speedo, and check the inner spindle drive is not dragging against the magnetic drum that moves the speedo needle to show your speed. While you're at it withdraw the INNER cable from the speedo cable using a pointy pair of pliers and coat it with vasaline and reinstall. if it still plays up the speedo drive is stuffed -
2012 Hilux 3.0 D4D starts, runs for 30 seconds then stops
Also, I have pulled an injector and fuel is coming out of it...so whilst i am not sure how much pressure is there, diesel is being fed up to the injectors...so the problem i think is electronic in that the injectors are not pulsing. Now i know that the injector pulse controller is working because the car has been started and ran for up to 30 seconds on a number of occasions I have disconnected the MAFS, cleaned out the MAF but it doesnt make any difference. It appears to me that the computer is disabling the injection system for some reason. -
hi guys, my son drowned his Hilux in 4 feet of water a week ago. (note car has a snorkel) I stripped out the alternator, starter motor, PCM and Turbo Wastegate controller, drained oil, removed filter and replaced, as well as went around the lower part of the engine disconnecting and learning electrical connectors. I went through both fuse boxes (one under hood, second fuse box underneath steering wheel, and also disconnected cleaned and reconnected plugs all around the inside of the cab. We charged up the battery, gave the engine a 720 degree hand crank with a socket on the harmonic balancer to ensure it wasn't hydro locked pulled the exhaust immediately after the turbo to check no water had come up the bum and into the turbo removed and checked airbox and flexible turbo intake piping checked there was no water ingress through the intercooler After all of the above, we hit that start key and she fired up immediately. I then immediately shut it off to check a few connectors and see if any error codes were registering still on the ODB port...I cleared them. Thats when all the trouble began... The car wouldn't start after this. We removed battery and put it back on charge and left it for the night. Next day, installed battery, turned the key...she fired up immediately. 30 seconds later it shutdown again...then refused to start. I removed battery, left it for an hour whilst mucking around with a few connectors and cleaning...plugged in battery again and voila....started back up again. Ran for about 30 seconds then shutdown refusing to restart again. Its the exact same thing over and over again. The ODB reader gives at least 2 error codes consistently 1. Barometric pressure in the manifold error 2. Turbo wastgate low voltage (I obtained another turbo wastegate controller however this had made no difference to the turbo error code) I am not convinced that the turbo or the barometric pressure are necessarily what is causing it to shutdown. Is it possible that water has somehow gotten into something related to the factory ignition disable system and is causing this? Ideas? -
24
FUEL WARNING MESSAGE
I had better finish off my saga because it definitely didn't end with the installation of the new (2nd hand) pump. I tested the new pump before installation and it worked fine. I installed the pump and reinstalled the tank. Knowing that the sub tank was full and the main tank was near empty, I expected the turning on of the ignition would have got the pump pumping. It didn't. I remove the relay that operates the sub-tank pump and it tested ok. I eventually worked out that there was no earth connection to the relay coil. There was +12V to socket for the other side of the relay coil and +12V at the terminal socket which connects to the pump when the relay closes. I connected a temporary earth to the earth side of the coil (using a fine piece of telephone cable wire which can be slipped into the socket before the relay is reinstalled) and the pump ran. I had previously identified this problem but concluded that the computer must control both the + side and the earth side of the relay coil, although I couldn't see why it would do this. My problem was that the the pump problem didn't always occur. If the gauge got to below a quarter and the fuel light didn't begin flashing, I could assume that the sub tank was near empty. But, sometimes the fuel light would commence flashing once the gauge got to 1/4 full and I knew that I had about 40km to go before empty. So, the new pump was behaving like the old pump and the problem must not be the pump. Fed up, I removed the relay, made up 4 short (4") leads with a spade on one end and a spade socket on the other end and connected the relay remotely. This then allowed me to connect another wire to the earth lead for the relay and take it to earth via a waterproof switch. If and when the fuel light starts flashing again, I will stop and switch on the switch to pump the contents of the sub-tank into the main tank. On reflection, this has probably been my problem all along and there was probably nothing wrong with the original pump (I convinced myself after reading about all the others who had had this problem that the electrical connection in the main tank had become high resistance and melted the fitting). I have not heard of anyone else who has diagnosed this to be the problem. I will post a photo of my fix later. -
24
I have a hoist so height wasn't an issue. But, if you run the rear wheels up onto ramps, you shouldn't have a problem. Remember, it is a 2-man job - one to support the tank and the other to connect the various pipes. Take a few photos of the pipe layouts before you remove them.
