[DIY] Replace your Shifter Bushings (2ZZGE 6SPD)
  • Replies 131
  • Created
  • Last Reply
Top Posters In This Topic
i am not sure i ave the pics anymore :(
i'll take a new batch when i get a chance.... or when i do someones bushes...
Any chances that can be mine :)
He's broken a foot so looks like you'll have to go to him .....
location aint an issue matey
also a 6 packer in it :spiteful:
hope ur foot gets better andy
  • 4 weeks later...
Hey Andy...Whats Going On? Yayyyy I Finally Have A Stivo...I Am So Happy...You Reckon You Can Hook Me Up With A Kit? (obviously i will pay for it...lol)
legend!!!!!
yeah mate... i'll get enough materials for a few kits... so when i have all the bits ready to go i'll post up a "for sale" thread.
congrats on the purchase mate!!! cant wait to meet you and your car!
Thanks mate. :) No Problem. Hopefully i will see the thread if i don't i would appreciate if you could send me a pm. :)
At the moment, everything is stock and pretty clean i must say. Once i recover financially, i will start to pimp it up! :D
  • 3 months later...
Ok Just installed mine today and here are my comments and installation guide:
1. Remove the catch can. I found that you just have to slide the entire box up and at the very end the hose will catch. Just put a little bit more force and the whole box will slide off. Don't put too much force. If you can't get this to work do what BKS says in the first post.
2.This is the thing you will be replacing and the clip that you cannot lose
3.Another view with both the horizontal and vertical ones
4.The clip after removal. Just use some pliers and pull it out
5.Pull the parts apart. Simple as lifting it up for the horizontal. Note: there is a washer on top that will probably fall off so make sure you take it off first.
6.Push the old bushing out. I found that my vertical one was easy to push out but my horizontal one I used a big phillips screwdriver and just pushed it straight through. (which caused it to fall through onto the ground) Note: I gave up on the horizontal one and thats why the pic is of the vertical lol
7. A pic of the bushing
8.A more clear pic of the bushing
9. Place the ball bearing into where the bushing was
10.Place the washers and spacers in and put everything back together. From BKS' pack I used this: big washer -> nylon washer -> small washer -> rubber spacer -> ball bearing -> rubber spacer -> nylon washer -> big washer. Putting the clip back on was quite hard but just wiggle it around and it will work
11. Put the catch can back on
12. Go and drive your car to feel the difference (yes there is quite a difference)
If anyone finds something wrong with this let me know and i'll fix it
Azzman372,
thats perfect mate great work! hope you're enjoying your new snappy gear shifting.
I gave it a run and it feels very different to the stock. You can kinda feel the gear changes? If that makes sense. But i'll be crusing with my mates evo 7 tonight so perfect timing haha.
Thanks for thie bits BKS
BKS,
i am willing to be the one that tries this out on their 1zz first... i am keen to get a kit... can i get one while down there?
are you going to be able to do that for me?
I will post the pic i took in a sec...
Evo
Here is whats shown above
Here is the pic i took this arvo
it looks to be very similar to what the sportivo should be :P
Evo
yeah i done this yesterday after work, i can kinda feel the gears but man can i change gears quicker :D i can be confident that the gears are in and wont crunch
The main thing is to make sure that the ball bearing can fit into where the rubber bushing was. from that pic the washer looks similar but thats all you can see unless you take a pic of the bushing.
Edited by azzman372
