A.Rices Auris "Blastwave" [SOLD]
Ascendant Rice
your exhaust is almost made the same noise as my one, where do you get it done?
Also, i love your wheels and nuts
My nuts are red as well
Also, did you spray red colour to your brake?
Edited by ben yip
I got it done at a small place in kogarah, friend painted my brakes with a brush lol
With the grille you should just keep the red OR the white, way too fussy with both tapes
+1
i reckon if u took off the white bars but made the whole edge red to contrast with the badge then it would look real nice.
Just installed my new I-Drive throttle controller, pretty much plug and play, noticeable difference, fun factor increase.
I am thinking about it, Does that mean the the throttle is more sensitive once in sport mode?
Edited by ben yip
Yes ben the throttle will more responsive in sports mode.
where did you get the TRD cap, i want to get as well, but I want the cap coming out a bit because the front wheel drive shaft is coming out, so flat wheel cap cannot be installed..
Also, love your carbon fibre badge... Are you a designer? you got talent in designing stuff
that DIY rear badge is gorgeous.
I think you can do the same for your antenna !!
and your side mirror, and your pillar between the front and rear windows
    6. 21
    7. 21
    8. 21
    10. 3
