51EKA's 99' Toyota Celica SX
51EKA
51EKA
All-Motor
[14.434@98.40mph 2.223 60' - Mods: Injen Intake, 2.5" exhaust, PFC]
Turbo
[12.878@114.02mph 2.170 60' @ 10.5psi/205.2kw (276hp~) atw]
PERFORMANCE:
• Apexi Power FC
• Apexi Boost gauge
• Stafford Fabrication Manifold (Modified by Extreme Custom Engineering)
• Stafford Fabrication Aluminium Fuel Rail
• Speedflow 100 Series Braided Fuel Line + Speedflow & Earl fittings
• AEM Fuel Regulator
• B&M Fuel Pressure Gauge
• Garrett GT3076r .63rear
• Tial 38mm wastegate
• MWR 630cc injectors
• Walbro 255lph fuel pump
• TRD low temp thermostat
• Bosch Bypass Valve
• Intercooler 550x200x88 2.5" inlet/outlet
• Custom stainless steel intercooler piping
• Custom stainless steel 2.5" dump pipe
• Custom stainless steel 3" exhaust w/ high flow cat
• X-force 3" Gold seam weld Muffler 4.5" straight cut tip
• Vibrant Ultra Quiet s/s resonator
• Denso IK24 spark plug
• K&N Pod filter
• ATP turbo accesories
• ATP Turbo braided oil feed line
• Speedflow 100 series oil return line
• Mr2 spyder idler pulley assembly
• B&M Short Shifter
• Exedy Heavy duty clutch
• Speed Source Brass Shifter Bushing
HANDLING:
• Kumho KU-36
• Pedders Adjustable Endlinks
• BC Adjustable Coilovers
• Hawks HPS Brake Pad Front
• Hawks HPS Brake Pad Rear
• TRD 3PT Rear Strut
• Cusco Lower Control Arm Brace
• Whiteline Front Strut Bar
• Whiteline Front Heavy Duty Adjustable Sway Bar
• Whiteline Rear Extra Heavy Duty Adjustable Sway Bar
• Whiteline Camber Adj Bolt Kit-15mm
• Whiteline Roll Couple Adjuster Kit
• Energy Suspension Polyurethane Rack and Pinion Bushing
• Energy Suspension Polyurethane Control Arm Bushing
• Energy Suspension Polyurethane Engine Mounts
APPEARANCE:
• “TRD” Center Tacho Conversion w/ white led
• Black Headlight Housing Conversion w/ oem internals
• OEM ZR 16" Wheels
• OEM ZR Fog Lights
• OEM 03+ Tail Lights
• OEM Elegant Front Lip
• OEM Elegant Side Skirts
• OEM Elegant Rear Valance
• Alloy Gear Knob
• OEM ZR Clutch + Brake Pedal
AUDIO:
• Pioneer MP3 Head Unit
• Jaycar Precision Response 6.5” Kelvar Split
• Jaycar Precision Response 6.5” Coaxial
• Jaycar Precision Response 12" Subwoofer
• Jaycar Precision Response 4x100rms Amplifier
VIDEO:
All motor:
Turbo:
Edited by 51EKA
Awesome set of mods you have there i think you and xoom need to line up!!!
pfffft ..... would be a waste of petrol for me to run jimmy .... especially with petrol prices these days :P :P
Xoom's still the master...
and dont u knw it biatch :P :P :P
For now... Hi Bill!!! :P
bring it biatch :P :P
Nice!
Im sure you can catch up to Bill in his 2ZZ turbo soon
come on jimmy ...... a little more ..... i mean .... how can the family rice bubble b handing the sports coupe its a.s.s to it ;) ;) :P
U knw me jimmy just stirring u ....... So man wen r u gonna finally open this baby up and dial up some real boost figures ;) ;) ;)
Hahaha.. I'm not in competition with Bill. Never built my car to be. ATM, there's no competition anyways. Comparing a old worn out standard engine/gearbox against a full-built engine/gearbox is just silly.
Anyways Bill's just small beans :P, I've got MUCH bigger goals (size of the turbo is a good indication of my plans, still too small even), but full-time uni and no job will be holding me back for awhile. Main goal right now is to keep it at a safe level so that the engine will hold up till I finish uni and get a job. But, I will be heading back to the track in the winter and aim for 12s on street tyres/standard engine. Once I've done that, it will be time for some slicks.
You need your car to be fast because afterall. It's still a family rice bubble, no matter what you do to it. :rolleyes:
Oh no... TOCAU is mostly corolla members...
Edited by 51EKA
study this view well jimmy ...... a sight u should continue to see from ur sports coupe' ...... the rear end of my family rice bubble as its leaving u down the straight :P :P :P :P
Damn.. I gotta look at that ugly thing? See... that's why I don't race you.
beauty is in the eye of the beholder ...... hence why i didnt buy an ugly Hairdressers car like the celica :P :P :P :P
Gotta Love The "Hairdressers Car" Call >_<
Nice Ride Sieka! :) Love The Black Colour Scheme! ;)
*Whispers I Hope One Day You Kick Bill's ***** So That He Can Shut It A Bit :P * Hahaha
very nice car mate!! i love it
i know bills car is faster and has more power so on and so on but i'd pick your celica over that anyday cuz its much more sexier =]
no offense bill ahhahahaha
  • 8 months later...
New dyno up.
arh saw your car briefly at the dyno day. Wasn't sure if you were a TOCAU member or not.
You got to be thrilled with that result :)
      1kzte throttle body
    3. 3
    4. 5
    5. 5
    6. 8
      PZQ60-00525 Issue
    9. 3
      Head Unit with Apple CarPlay
