Stud Pattern
safekraka
Hey guys
Please please please help
I have just put a bid on some rims on eBay that are from an Aurion and have realized i am not sure if they will fit my JZX90 ( yeah stupid i know)
If you could tell me the stud pattern that would be great.
thanks guys
Dave
Stock Sportivo 17" rims are +42 offset I think?
I was always under the impression that they were a +35mm offset. I know the Gen 5 Camry's were +42mm offset, but I don't know if the Aurion has the same. An interesting note, the Kappa rims which are an option for the Aurion come in +45mm offset. Hmmm.
Just looking at the wheel though, a +45mm offset seems more correct though. I guess I'll take out the tape measure next time I remove my rims.
All Aurion's and gen6 Camry's should be +45mm except the TRD which is +46.5mm.
I have some Presara wheels at home for my wifes gen6 and they are 17x7 +45mm.
Whats the going rate on the 17" Sportivo rims these days anyhow? I've got a full set sitting in the shed that I should probably offload at some point.
There is currently a set on eBay for $400 without tires. I've seen a set on there before with tires with a starting bid of $500 and I don't think those sold. They don't seem so popular.
Figured as much, think I'll just keep the set I got to swap out for rego if its ever needed.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
