2zzge Swap Into '98 Corolla
It would seem that's not the first conversion done on that car, if you read the thread he took out a 1ZZ to fit the 2ZZ.
Hopefully Craig will see that one ... over in the Paseo thread we were discussing the possibility of dropping the Snowflake's drivetrain into his friend's Paseo. We had nicknamed the project "Flake-enstein" but Craig dismissed the idea.
Maybe this thread might change his mind ... :P
Hmm. If you read up until the end he mentions a problem about not being able to get lift. I'm intrigued. Might have something to do with the coolant temp sensor maybe? that's the only thing i can think of. anybody?
I wonder how she runs down the 1/4mile? :D
Edited by qkslvr
Where did the donor Matrix come from?, it looked to be in 1 piece, Insurance Job?, what's he going to do with that now ?
Also notice how that was the early version of the 1zz-fe motor with the Aluminium Intake plenum and square throttle body, that's since been replaced with the lightweight plastic intake plenum and regular round throttle body.
I helped wire this car over email/forum posting.
The donor car was a written off matrix, they couldn't get lift because the speed sensor wasn't connected to the ECU.
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
