steering
so i put a set of coilovers in and yes they are the ones that shall remain nameless that start with D and end in 2
when i went to get a wheel alignment the guy at bob jane said that my steering was off. what happens is that when i turn the corner and let go of the steering wheel it would usually correct itself but it keeps going on that same angle and does not straighten up naturally
anyone got any suggestions
Mine does the same mate. I dunno why. Btw I'm running the same sussy as you.
Probably has something to do with the coil overs and the new angle the wheels sit at...
If the car still drives straight and all the wheel alignment figures are correct then it's not really something to worry about... Keep your hands on the wheel at all times and you'll have no problems :P ...
they adjusted all the steering to straight but the steering wheel it doesnt straighten up to centre after a corner :(
Edited by lylee
mine is exactly the same. Had them for a while now, 2nd hand. But I kinda don't think about it anymore. It used to bug me at first but not anymore.
Perhaps it's the oil in the struts itself. Perhaps it's too thick, so slower rebound?
Get an alignment at a decent specialist and get a printout.
WHY OH WHY do people just buy cheap rubbish coilovers???????????? Shocks are probably THE MOST IMPORTANT part of a car (maybe tyres). I don't understand why PPL skimp out on em. U'd have a WAY safer, WAY better handling, WAY more comfortable car with just King Springs and Bilstein B8 shocks for a similar price.
Bloody ricers.
Go see Fulcrum and get it done properly. But you might have to settle for less camber or castor...
Gav.
The OP isn't lucky enough to have a Fulcrum nearby. Lucky for us though living in Queensland.
Hey,
Sorry i didnt see your post earlier.
I had the same thing and the guy that did the alignment said that because of the castor/camber when you let go of the wheel it wont flick back into the centre as it did on the stock setup. I dont know the technical terms for it
At first this was annoying but you get used to it as time goes on.
Did you fix the knocking noise?
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
